After flashing ECU
mattfzz
After flashing ECU
Post by mattfzz »
Hi guys I'm new to HONDATA. I have a 2018 Honda Accord Sport 2.0T. I had uploaded a calibration to my ECU and proceeded to drive the car. I was pulling the car when the acceleration cut off and the check engine light was blinking. I pulled over and shut the car off and turned it on a few minutes later and everything was fine. Did I have to let the car sit idle before driving it or drive it more reserved? Or did I have to turn it off first? Please let me know. As of right now the car is ok and working fantastic and have not run into the same issue. Thank you!
Re: After flashing ECU
Have you datalogged to see if there are any error codes?
