Windows 10 or android tablet as a display screen
ohisofly
Post by ohisofly »
I have an s300v3 and would like to install a windows 10 tablet or android tablet as a display screen. I've searched and seen variants of this question but not a clear answer - I apologize if I overlooked something. I'm not sure if a tablet would have to be manually connected via bluetooth every time the car is started, or if it could be connected via usb to the hondata to get around that issue.
Is there a way to use the tablet with a permanent dash or gauge view, so when you turn on the car it loads directly to that? That's why I was thinking it'd be ideal to connect this via the usb cable but I'm not sure how that works.
Any clarification on connecting an android or windows tablet and using that as a permanent display screen would be much appreciated.
Thank you
Re: Windows 10 or android tablet as a display screen
No it will not open the app and connect automatically. The Windows application can connect via USB, but you must still connect every time.
