K pro wont connect via USB after 4.4.6 update
BusterWolf
Post by BusterWolf »
Was working fine before firm wear update. USB driver gives an error now. My check engine light is on but was find before. Tried to call and you aren't taking calls now. When plugged up it says driver installed but is offline. Cant even connect via Bluetooth. Please advise ASAP.
Re: K pro wont connect via USB after 4.4.6 update
What is the serial number that is on the K-Pro board?
BusterWolf
43860
The red and green lights are alternating flashing.
unplug the ECU from the vehicle and then only plug in the USB and see if it will update firmware.
