K pro wont connect via Bluetooth after 4.4.6 update
Ecky
Post by Ecky »
Hi all,
A few days back I took the 4.4.6 update to KManager, and found that, after the update, my KPro was no longer showing up in the "Select Bluetooth Device" window.
I checked in Windows and verified KPro was paired - which it was. So I deleted it, uninstalled the driver, then re-paired it. I can see it in Windows, but in KManager it still doesn't appear.
The next thing I tried was connecting via USB. This worked immediately, and I was asked to send a firmware update. After that, I re-flashed my calibration, disconnected from USB, and tried connecting via BT again - same deal. I even reconnected via USB and changed my pin, uploaded that, re-paired with KPro in Windows using the new pin, and still nothing.
Any ideas?
Re: K pro wont connect via Bluetooth after 4.4.6 update
Did you upload your calibration to the ECU after the firmware was updated?
Ecky
Post by Ecky »
Yep!
Ecky
Post by Ecky »
Great, can do!
