04 tsx flashpro not finding 07 ecu
Mikeedc4
Post by Mikeedc4 »
Any ideas? After hooking up can harness says ecu not detected. Also used a line tap. A clip from can harness stuck inside green plug reason for line tap...
Re: 04 tsx flashpro not finding 07 ecu
really hard to tell based on the limited info.
Mikeedc4
Post by Mikeedc4 »
Hooked up hondata flashpro to laptop and it said ecu not detected with everything connected
Mikeedc4
Post by Mikeedc4 »
Will a line tap work same as pinning the green plug?
You will have to post a picture showing what you are describing.
Mikeedc4
Post by Mikeedc4 »
The pin from can harness wire came off inside green plug. So tuner used a line tap
Mikeedc4
Post by Mikeedc4 »
I did see a write up on the ground going to rocker cover. I do not have a ground on it I looked
Mikeedc4
Post by Mikeedc4 »
Is ecu not detected due to immobilizer for 07 ecu?? Anyone
You have not provided pictures showing what you are describing.
