Throttle body adjustment/ help?
Cyber160
Post by Cyber160 »
I am new to Hondata. I did watch a few videos to help me get started, but I do have a couple of questions. One why the read-option isn't available on the tps part of calibration? two I have a bigger throttle body in this do I have to adjust for it or would it adjust after reading it?
I used a stock b20 base calibration just to get it running because that's the engine I have in this car everything engine and trans is stock except the throttle body.
thanks in advance
Re: Throttle body adjustment/ help?
You can calibrate it when you have the calibration open, and you datalog. It will allow you to read open and closed. Reupload to the ECU, Make sure you save a cop of your calibration to the hard drive.
Cyber160
Post by Cyber160 »
Thank you ill have to try it when i get my car back from the shop next week.
let you know if i have any success.
Cyber160
Post by Cyber160 »
FINALLY got a chance to start this again, now i have new problem it doesn't seem like the software is reading the sensors or anything, i cant even see rpm with it. i tried data logging but its just straight lines nothing is changing even when i revved it a little to get things to change... so lost, any help appreciated
Who socketed the ECU?
Is J12 cut inside the ECU?
