Euro 2020 FK8
CivicVTi
Euro 2020 FK8
Post by CivicVTi »
Hello. Can this be remotely jailbroken? (with CAN gateway)
ECU part 37805-5BF-E34
Re: Euro 2020 FK8
It should work but has not been tested.
CivicVTi
Re: Euro 2020 FK8
Post by CivicVTi »
Hello. ANy updates on this? Do I need the CAN gateway to perform remote jailbreak? I think not since europe models are different. Please advise, I have an appointment next monday and do not want to lock customer's ECU. Thanks!
Re: Euro 2020 FK8
If you plug in the FlashPro to the vehicle in the FlashPro window under jailbreak it will show 'unknown' or '2020+' if it needs the jailbreaker. If it has "Yes" or "No" then it does not need the jailbreaker.
CivicVTi
Re: Euro 2020 FK8
Post by CivicVTi »
Perfect. Will let you know on Monday. thanks !
CivicVTi
Re: Euro 2020 FK8
Post by CivicVTi »
Unfortunately, the MY20 Euro FK8 needs the jailbreaker (flashpro showed 'unknown' under jailbreak tab). Hondata I will contact you soon to either send you in the ECU or get the jailbreaker module. THanks
Re: Euro 2020 FK8
The ECU should not be sent to us. It will need to use the instant jailbreak and jailbreaker.
orcunince
Re: Euro 2020 FK8
Post by orcunince »
Hello all,
My Ecu Code is: 37820-5BF-G34
Car spec: EU
My jailbreak status isn't unknown, it is 'not jailbroken' so i bought instant jailbreak but when want to jailbreak the ecu an error comes 'jailbreak failed'. What should i do?
Re: Euro 2020 FK8
That ECU is not supported. If you wish we can send you instructions on how to read the ECU and send that to us.
orcunince
Re: Euro 2020 FK8
Post by orcunince »
Hi,
Yes please, lets do it! :)
Hondata wrote: Sun Aug 01, 2021 8:24 am That ECU is not supported. If you wish we can send you instructions on how to read the ECU and send that to us.
Re: Euro 2020 FK8
