A few questions before buying / install
Furble
Post by Furble »
1) I've already re-purposed the brake switch input for something else, will this be an issue for traction control to function properly?
2) Given it's a front-wheel-drive car is there a need to hook up the rear wheel sensors up to the unit? What purpose do they serve? I think it may be so the system can see that the front wheels are spinning faster than the rear and thus slipping, but wanted to verify.
Re: A few questions before buying / install
You can use a different input for the traction control.
You must have both front and rear sensors for it to see a difference between front and rear.
Furble
Post by Furble »
So it does not depend on the Brake switch input being stock/operable to be able to distinguish when brakes are being depressed?
no
