hondata cpr crank but no start vid inside
justYncredible
Post by justYncredible »
vehicle
95 integra gsr obd1 ecu s300v1. if i didnt say it the power, ignition and sync led all come on
https://www.youtube.com/watch?v=MdkU4yToCyg
Re: hondata cpr crank but no start vid inside
justYncredible
not yet, i can do that this week and ill follow up on my finding. if not its not giving spark, what would be the next step?
We can't pre-emptively troubleshoot.
justYncredible
make sense. ill get back to either by friday or saturday just have been busy with work,
justYncredible
no spark. in the video you can see i have placed the spark plug next to my AN fitting that is stainless steel. any other test
https://www.youtube.com/watch?v=uAdZnP4B_Vw
It can't just be next to bare metal it must be in direct contact, and that fitting is isolated by rubber gaskets and is not actually grounding. Use a stud on the valve cover instead.
justYncredible
sorry for the delay just had a busy week but here is another clip next to the acorn nut on the valve cover. i dont see any spark
https://www.youtube.com/watch?v=qXy00ftpxTI
Is Q37 transisiter installed in the ECU?
justYncredible
yes it is present from the factory, is it a possibility that i may have the two wires that come off the engine harness flopped? the power and tach wire is what im referring to.
https://imgur.com/Jvei9sp
https://imgur.com/ccyz7k2
You appear to have them swapped. This may cause damage form being miss wired.
justYncredible
success! yeah those two wires were wrong. could you have your team look into updating the instructions for those wires? maybe some up to date visuals, itll help. ill take the car for a spin this weekend, its been awhile since i last drove it. (dont mind the squeaky noise, got a some things to tighten on the body and yes that is a 1jzgtevvti in the corner with a r154 :-)
https://www.youtube.com/watch?v=YU-DdNbqqJc
