2018 civic si turbo upgrade wastegate code
Civic 2016+ 1.5 Turbo
Bryceb466
Post by Bryceb466 »
Just installed a new turbo now car has p003a code unsure how to address this i am new to tuning any help is appreciated
Re: 2018 civic si turbo upgrade wastegate code
Does the new turbo use the factory wastegate?
Bryceb466
Post by Bryceb466 »
Yes factory electronic Wastegate
This code means the wastegate position is out of range when the wastegate is closed. It is not a tuning or ECU problem.
lightarmy10
Post by lightarmy10 »
Hondata wrote: Sat May 01, 2021 11:35 am This code means the wastegate position is out of range when the wastegate is closed. It is not a tuning or ECU problem.
Hi , i also got the same problem right now , last week i installed a big turbo to my 2018 Civic 1.5T CVT after that i try to pull WOT 2-3 times and the engine check lights turn on , the DTC code is P003A. i didn't touch my original wastegate (loosen / tighten) , but the DTC comes up... can you give me the solution to fix these problems? thank you
What company is this turbo upgrade from?
lightarmy10
Spunkster wrote: Tue Jan 04, 2022 11:14 am What company is this turbo upgrade from?
Mamba Turbocharger
