External Westgate
Semin1907
External Westgate
Post by Semin1907 »
Hello Team
I want to use big turbo with external westgate controlled by profec. I want to learn that how can we control the boost pressure with only boost controller ? Car will calculate airc and torque request so do i have to cancel maf sensor ? I m planning to target over 35 psi.
Thank you
Re: External Westgate
Hondata does not support the removal of the factory wastegate. You could try removing the factory wastegate and then disable any errors that come up, but I can't say what the ECU will think of that. Not sure what the AFM has to do with the wastegate.
