Issues with Display for pressure sensor 0-100psi data.
fryguy190
Post by fryguy190 »
I previously had my display settings set up for my oil and fuel pressures set up under analog 1 and 2. using autometer 2246 pressure sensors. on my display they use to show the psi conversion. but since the new update they seem to only show me voltage now. Is there a way to switch it?
Thanks in advance.
Re: Issues with Display for pressure sensor 0-100psi data.
fryguy190
Post by fryguy190 »
id have to look when i getback to the house. left the laptop at home. I just remember the update being from March 11th this year.
fryguy190
Post by fryguy190 »
It is version 2.7.6.0
Please download the most recent version
fryguy190
Post by fryguy190 »
So i updated to 2.7.7.0 and still no luck. also ive been having an issue with the engine not revving past 2500 rpm. i had a feeling it is a corrupt file on the s300. so i built a new tune and uploaded it to the ecu with the key on engine off. then turned off and turned back on. went to download the tune to make sure it took and i got nothing.
my s300 serial # 50559
Post your calibration and a datalog showing the issue.
Who socketed the ECU?
Can you post pictures of the soldering on the bottom of the ECU?
fryguy190
Post by fryguy190 »
I honestly have no idea who socketed the ECU I purchased it second hand.
it was working just fine for months.
i also just found under s300 information that the datalog memory test failed and flash memory
Send an email to support<at>Hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread
fryguy190
Post by fryguy190 »
sent
fryguy190
Post by fryguy190 »
About to send it out. But I was going to ask as well. I had purchased a Digital dash to run over CAN and I’ve had nothing but issues with it since day one. I was curious if I was about to send it in with the ecu and Hondata to figure out what was going on with it not communicating.
We have no way to test an aftermarket dash with the K-Pro.
fryguy190
Post by fryguy190 »
Are you able to test if there is signal coming for the CAN? also it’s S300
Sorry, I meant s300. We have no way of testing the CAN outputs at this time.
S300 CAN output tested and working as expected.
