Issues with Display for pressure sensor 0-100psi data.
Posted: Mon May 10, 2021 8:24 pm
by fryguy190
I previously had my display settings set up for my oil and fuel pressures set up under analog 1 and 2. using autometer 2246 pressure sensors. on my display they use to show the psi conversion. but since the new update they seem to only show me voltage now. Is there a way to switch it?
Thanks in advance.
Re: Issues with Display for pressure sensor 0-100psi data.
Posted: Tue May 11, 2021 9:12 am
Posted: Tue May 11, 2021 9:22 am
by fryguy190
id have to look when i getback to the house. left the laptop at home. I just remember the update being from March 11th this year.
Posted: Tue May 11, 2021 4:54 pm
by fryguy190
It is version 2.7.6.0
Posted: Wed May 12, 2021 9:44 am
Please download the most recent version
Posted: Wed May 12, 2021 6:11 pm
by fryguy190
So i updated to 2.7.7.0 and still no luck. also ive been having an issue with the engine not revving past 2500 rpm. i had a feeling it is a corrupt file on the s300. so i built a new tune and uploaded it to the ecu with the key on engine off. then turned off and turned back on. went to download the tune to make sure it took and i got nothing.
my s300 serial # 50559
Posted: Thu May 13, 2021 10:19 am
Post your calibration and a datalog showing the issue.
Who socketed the ECU?
Can you post pictures of the soldering on the bottom of the ECU?
Posted: Thu May 13, 2021 6:09 pm
by fryguy190
I honestly have no idea who socketed the ECU I purchased it second hand.
it was working just fine for months.
i also just found under s300 information that the datalog memory test failed and flash memory
Posted: Fri May 14, 2021 10:10 am
Send an email to support<at>Hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread
Posted: Fri May 14, 2021 1:53 pm
by fryguy190
sent
Posted: Wed May 19, 2021 2:48 pm
by fryguy190
About to send it out. But I was going to ask as well. I had purchased a Digital dash to run over CAN and I’ve had nothing but issues with it since day one. I was curious if I was about to send it in with the ecu and Hondata to figure out what was going on with it not communicating.
Posted: Wed May 19, 2021 3:20 pm
We have no way to test an aftermarket dash with the K-Pro.
Posted: Wed May 19, 2021 3:23 pm
by fryguy190
Are you able to test if there is signal coming for the CAN? also it’s S300
Posted: Wed May 19, 2021 3:53 pm
Sorry, I meant s300. We have no way of testing the CAN outputs at this time.
Posted: Thu May 27, 2021 4:37 pm
S300 CAN output tested and working as expected.
