ECU for K24 swap
Swapme
ECU for K24 swap
Post by Swapme »
I have JDM k24a that I want to Swap in to a Porsche 914 with a boxster trans.
I have a PND A51 ECU. One place says a A51 cannot be used to install a v4 board, another site says an A51 can be used for a swap I just have to get vss to the v4 board.
Can I use the PND A51 ECU with handata v4? Or will I have to get a different ECU thanks.
Re: ECU for K24 swap
Details on using an automatic ECU can be found at: https://www.hondata.com/tech-alternativ ... ngine-swap
