When the RPMs increase, a warning appears.
Civic 2016+ 1.5 Turbo
Lass
Post by Lass »
I am using Civic Turbo MT 2017,+3 psi.
I just changed all the other settings as per the instructions, but when I rev in gear 2, all the warnings show up.
If anyone has any ideas as to what might be causing this, I'd love to hear from you!
Thanks!
Re: When the RPMs increase, a warning appears.
What warnings do you mean?
Have you datalogged and checked for error codes?
Lass
Post by Lass »
I'm sorry. I didn't use the right words.
All the warning lights are glowing.
If I rewrite the ECU again, it goes back to normal, but if I rev it to about 5000 rpm again, all the warning lights light up.
You must datalog and check for error codes when this happens.
540999115@qq.com
Post by 540999115@qq.com »
When the stock VSC system can not effectively stabilize the car (include tire skipping,sliding)all the alarm lights will on.
You just need to turn off and restart the car,drive normally and strightly for about 1~2km,the lights will off.
You can select "disable VSA" in the mods.
