Looking for a specific kpro
Jinzo2678
Post by Jinzo2678 »
Does Hondata make a ecu for a 02-05 Si that has the original engine in it, but a 6 speed transmission from a 02-06 RSX Type-S? I need an ecu that has the reverse gear lockout if I wanted it. I can't just swap the ECU out from the donor RSX (it'll think it'll have a K20Z1 when in reality it'll have a K20A3), so I figured maybe Hondata has a solution.
Re: Looking for a specific kpro
Hondata does not make ECUs at all. You could use a PRB ECU, or could nitrous output for the reverse lock.
