engine cuts out at 2k rpm and 4k rpm not moving
justYncredible
Post by justYncredible »
i just got everything running in this kit a wanted to take the car for a spin. when i reach 2000 rpm the engine cuts out which i dont understand why its doing this. so i limped my car back into the garage and when parked the car will cut out at 4000 rpm. why is this happening?
Re: engine cuts out at 2k rpm and 4k rpm not moving
If you datalog are there any errors?
justYncredible
for context
parked map is my car in the garage
1st gear is driving on the street in my neighborhood. it happens in other gears as well
Your TPS does not appear to be reading at all.
justYncredible
you was correct sir! the way i have my tps wired, for when i needed to calibrate it, the connection i had to the center wire was disconnected. plugged it back in and took my vehicle for a spin around the neighborhood. so far so good, just need to revisit the tuner to complete the tune
