Which basemap is best for civic si 2018
Civic 2016+ 1.5 Turbo
Murrkk305
Post by Murrkk305 »
Hello everyone
I’m buying a flash pro from someone today. I really wanted to know which base map is good for a stock civic si 2018? +6 or can I use +9 psi without any problems. Thank you in advance.
Murrkk305
Re: Which basemap is best for civic si 2018
Post by Murrkk305 »
Y’all finna help me or na?
The +9 psi may cause the clutch to slip.
Murrkk305
Post by Murrkk305 »
Thank you, I’ve been using +9 psi for a week and no clutch slippage yet thank god. I also added a prl short ram intake street maf, do I have to tune it on hondata?
That is up to you. If you want to get the most out of it, it can be tuned on the dyno.
Murrkk305
Post by Murrkk305 »
I’m saying though, is there a pre set basemap for the prl street maf? Or would it have to be a custom? Cause I read that only the prl race maf intake has to be set on the hondata
There are no custom tunes or mods for that MAF housing.
Murrkk305
Post by Murrkk305 »
Thank you fam
