21 Acura TLX 2.0T (Flashpro)
F23A4
Post by F23A4 »
Hello all. Is there a Flashpro solution in the works for the 21 Acura TLX 2.0T? If not, is there any compatibility with the Flashpro for the 18+ Accord 2.0T?
Thanks,
Lee
Re: 21 Acura TLX 2.0T (Flashpro)
There is not currently anything planned. The Accord FlashPro will not work.
As a note, similarities in engines between models makes no different to the amount of work it takes us to support new vehicles.
The example I give is that the two closest FlashPro models from a development point of view is the S2000 and 2007 Fit.
F23A4
Post by F23A4 »
Thank you.
ayau
Post by ayau »
I wonder if there's a bigger engine ECU correlation if you look at where the car was manufactured and possibly share the same parts bin.
S2000 and 1st gen Fits were both made in Japan.
