Can you ad more sensors to the analog inputs?
Korn4900
Post by Korn4900 »
I have been having trouble seeing up the custom setting on my analog inputs. I wanted to know if you can ad some aem sensors pre programed.
Re: Can you ad more sensors to the analog inputs?
Can you be more specific?
Korn4900
Post by Korn4900 »
Aem 30-2131-100 and 30-2131-30 and 30-2012
Should work as a custom sensor as they are linear. What settings are you using?
Korn4900
Post by Korn4900 »
Hondata wrote: Sun May 30, 2021 6:57 am Should work as a custom sensor as they are linear. What settings are you using?
The sensor reads like 1400psi when the engine is on
Ah, the trick is that the custom sensor units are in bar. Try 0 and 6.89476 for the values.
