Need help with tune
Dirtypool
Need help with tune
Post by Dirtypool »
Hi. I k-swapped a 1966 Datsun roadster.
It is a JDM K24a with RBB head and a Kpower intake. The header is custom made with 1 3/4 primaries and 2 1/4 exhaust. Kpro v4 non type s (pnd?) ecu.
If I load a pnd stock tune, it will not start at all. If I load a TSX tune from the list, it will start and run poorly. I mistakenly bought a 4 Bar MAP, but I am not boosted so I should have bought a 1 Bar MAP. If I set my tune to the parameters of the 4 bar map, it will run worse and die. If I tell it there is a stock MAP, it runs better.
Lots of black smoke and idle and low rpm. It cleans up in the midrange. in higher RPM the engine will just quit.
Here is the tune that I had the best luck with.
rob1.kal
Here are a few of the datalogs
46sec.kdl
29sec.kdl
One tune had the A/F at 14.x and another had it at 11.x. Stock injectors. The injector figure in ms is always in the red at approx 22ms.
The local tuner is ghosting me and even if I wanted to tow the car 3 hours away, those tuners also have not returned my call.
Let me know if you would like to see other datalogs that I pulled.
Thanks for your help.
Rob
Dirtypool
Re: Need help with tune
Post by Dirtypool »
Also, I don't have access to another car to try this ecu/tune in.
Dirtypool
Post by Dirtypool »
Update:
I bought a 1 bar MAP sensor and changed the spark plugs.
This is a new datalog...
0612.kdl
When driving the car, there is quite a bit of smoke from the exhaust still. When holding maintenance throttle i.e. staying at 30mph, the car burbles and is not smooth.
When letting off of the throttle, the car will sometimes give you throttle for about a second or more. Also, I cant go past about 2/3 throttle or it stumbles, cuts out and sometimes backfires.
While it runs better than the last datalog it still has some issues.
Thanks.
In the last datalog, the data appears to be frozen and is not moving.
Dirtypool
Post by Dirtypool »
Strange.
I just checked the source file and it is the same way.
Next time I drive it I will get a longer data log session.
CalibratEd
Post by CalibratEd »
I can help you out once you figure out the datalog freezing issue. The other datalogs worked. Also, you will need to log the car longer than what you posted. The basemaps are a good start but will always need work.
-Ed
Instagram: calibrated.tuning
Dirtypool
Post by Dirtypool »
Yeah. Will do.
Not sure why the injectors are always in the red at about 20ms. Not sure why it cuts out at about 2/3 throttle. Hopefully I can get an updated log tomorrow.
Thanks for the help. I appreciate it.
CalibratEd
Dirtypool wrote: Tue Jun 15, 2021 8:30 pm Yeah. Will do.
Sounds good.
-Ed
Dirtypool
Post by Dirtypool »
Ok.
Drove it today.
This is the calibration file:
rob1.kal
And this is driving it around the block:
0616a.kdl
Dirtypool
Post by Dirtypool »
I think those files are out of order on my last post.
I also drove it down the street but my datalog file is 600k over the 10mb limit so I can't upload it.
When I drove it down the street, it died when I was slowing down for the traffic light. I let the clutch out in second gear and it restarted but died again as I was going through the intersection. I pulled over and tried to start it a few times, then it started and stayed running so I drove it back. If I can find a way to shorten that file I will post it up here.
Thanks.
Dirtypool
Post by Dirtypool »
I have an error message for the vtec oil pressure switch. The engine is a JDM K24 so it does not have a vtec oil pressure switch
CalibratEd
Dirtypool wrote: Wed Jun 16, 2021 5:56 pm I think those files are out of order on my last post.
Thanks.
Open the datalog in KManager, on the timeline right click about 15-20 minutes into the datalog and select "set new end". Save it with a new file name and upload it.
It looks like you need to start with a good base tune and then dial it in. I would like to see the datalog where you drove it on the street. The most recent datalog is the car warming up at idle.
-Ed
CalibratEd
Dirtypool wrote: Wed Jun 16, 2021 6:00 pm I have an error message for the vtec oil pressure switch. The engine is a JDM K24 so it does not have a vtec oil pressure switch
This is a simple fix. You have to uncheck this in the calibration file.
-Ed
Dirtypool
Post by Dirtypool »
Thank you.
Shortened version.
shortened.kdl
Dirtypool
Post by Dirtypool »
CalibratEd wrote: Wed Jun 16, 2021 8:00 pm
Thanks.
-Ed
The first minute of that datalog was warm up and backing out of garage. Then I drove around the block. You can see the rough running maintenance throttle i.e. holding at 30mph.
I don't have anything hooked up to the vss so it won't show speed.
