2021 Honda Accord Touring 2.0T Flash Pro available?
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
HondaDriverNamedJose
Post by HondaDriverNamedJose »
Hello, A few years back I purchased a flash pro ( non carb ) for my 2018 Accord 2.0T.
I just recently traded into a 2021 Accord Touring 2.0 and was wondering if the same unit is compatible with my 2021?
If so do I just select the same calibration profile as the previous model?
Thank you for your help!
Re: 2021 Honda Accord Touring 2.0T Flash Pro available?
What is the ECU part number on the new vehicle?
Did you return to stock and unlock the FlashPro form your original vehicle?
Thank you for the response! I actually sold my Flash Pro a few weeks prior as I was not expecting to purchase another Accord. I did the return the vehicle to stock and unlocked the car before selling. I would be buying the same model online from Hondata or a dealer I believe the part number is (FP-ACRD-US) . My ECU number is 37820-6B2-C54 Thanks again!
That ECU is not supported at this time.
MKEaccord21
Post by MKEaccord21 »
Hi, do you expect to add support for this ECU?
Thanks!
Probably at some point in the future. We are working on a lot of things and doing them as quickly as we can.
MKEaccord21
Thank you! I (stupidly) bought the flash pro accord 2018+ CARB without checking the ECU number. Will I need a different flash pro unit when the 2021 accord flash is available, or will I be okay with the unit I purchased?
That unit will work when supported
MKEaccord21
Thanks for the replies!
