VSS Output Kpro v4 02 rsx type s
Rflowers01
Post by Rflowers01 »
I have a 2002 rsx Type s k20a2 engine 6 speed transmission both original to the car. I Have installed a70mm throttle body and a skunk2 injen cold air intake and skunk2 intake manifold. Injectors have been increased to 410 cc.
After installing the Kpro V4 all is well except a P0500 error code. After researching, this forum as others, it led me to the fact that the ecm has no input from the VSS. The rub is that I cant find the fix. I have double checked that the sensor is set to low frequency and that the proper transmission has been selected. The only fix so far is selecting the constant speed choice but that choice seems to render VTEC useless.
By the amount of posts seen it is definitely a pattern failure and I know one of you gurus have figured this out.
Thanks in Advance
Re: VSS Output Kpro v4 02 rsx type s
What is the serial umber that is on the K-Pro board inside the ECU?
What is the ECU part number that is on the white plug inside the ECU?
Rflowers01
SN from Board 580084 or T1Y -d3
Sn on white plug 37820-pnd-a55 2063-506584 od26
I think that's what your after
The ECU you are using does not have an input for VSS. Please see the info at: https://www.hondata.com/tech-alternativ ... ngine-swap
This ECU should not be used in an RSX.
Rflowers01
Any cure or just reorder another ecu?
You should use the correct ECU from a manual RSX Type S.
