Need a base map to get my car to the tuner
2001 civic si
Ls vtec turbo
Pieced together turbo kit
Open exhaust to the ground
Precision 780cc injectors
P28 s300 converted to obd1
Burton coil on plug conversion
Stock map
Stock block and head
Before s300 was on chipped p28 Neptune ran rich at 10lbs
Currently on map from ha Motorsports car af gauge jumps over 15.0 to --- and cuts out when even being moved.
Please help
Ls vtec turbo base map needed
Spriggs727
Re: Ls vtec turbo base map needed
The af gauge goes from 10.0 to dashes and the engine cuts out
- CalibratEd
- Contact:
Post a datalog and the Calibration file you are using.
Also, have you reached out to your tuner and asked if they can provide you a base tune to get you to their shop?
-Ed
-Ed
Instagram: calibrated.tuning
