p30 s300
jaeda
p30 s300
Post by jaeda »
need assistance
once i use my p30 with s300 to my coupe b20b rev limit 4000, however if i transfer my box to my hatch with b20b it doesnt have rev limit. i already tried different rechip box no rev limit.
i also tried erasing the basemap on the p30 unable to erase it.
Re: p30 s300
Have you datalogged and checked for errors when it is rev limiting?
jaeda
Re: p30 s300
Post by jaeda »
errors
map sensor
tps
chk
knock
however with different box no issues
Re: p30 s300
Its sounds like an issue with the ECU. Have you tried your s300 in a different ECU?
jaeda
Re: p30 s300
Post by jaeda »
i tried the ecu with different car it runs fine no rev limits
Re: p30 s300
Then it sounds like there is a problem with the sensors and wiring in your vehicle, and that will have to be fixed.
