2018 civic 1.5T Limp Mode
Civic 2016+ 1.5 Turbo
Jclrk279
Post by Jclrk279 »
I recently had some error codes pop up and cause my civic to go into limp mode. About a month ago it started. I took it to Honda they checked it out and said it was the O2 sensor. They replaced it, the codes were gone and it seemed to run fine for a couple weeks. I have the +3 map loaded and always run premium fuel. Yesterday on the way home I was at a stop sign and as I proceeded through the stop sign it went into limp mode again. I could only go about 5mph. These errors came up PA 18; DTC U0100; DTC in a square box: 27, 30, 33, 42, 60, 103, 112, 113, 118, 119, 128. I took it back to Honda last night and they said it was likely from the aftermarket RV6 catted exhaust/frontpipe and I would probably need to get it dynod. Anyone else have a similar issue? I'm pretty sure it's not the exhaust cause I've been running it Since May of 2019 and never had this issue until now.
Re: 2018 civic 1.5T Limp Mode
If you datalog what error codes are reported?
Jclrk279
Post by Jclrk279 »
Unfortunately I wasn't able to get it datalogged while the errors were there. After I got it back from the dealership their were no errors but i decided to datalog and drive around in town and on the highway, to see if anything came up again. Nothing did but here is a link to my datalog, maybe you can see if anything looks abnormal to you.
\\https://1drv.ms/u/s!AgCZIinGdJ8PjhpCoMo ... 7?e=pqOmmh
Without any error codes, there is nothing really to give us more info. If it happens again you need to datalog and see what errors are reported.
