Fuel Maps
Lomanrams21
Fuel Maps
Post by Lomanrams21 »
Have a 2013 Civic SI. Put a turbo kit on it, Have DW65c Fuel Pump and ktuned fuel rail and ID 1050 Injectors. When messing with the fuel map it seems like i have to dump way more fuel into the map just to get the car to run. IT should run on a basemap, but it wont unless I dump fuel into it. Rail pressure is all good and they are brand new injectors. IT runs great and had it tuned but the tuner was concerend because of the amount of fuel he was putting into the map. ALmost like the ecu wasnt accepting the bigger injectors. Any ideas?
Re: Fuel Maps
Have you put in the correct dead times for the injectors you are using?
Lomanrams21
Re: Fuel Maps
Yes I did do that. I beleive, your talking about the chart they send you and what not and you plug that new info into flashpro right....?
Re: Fuel Maps
The dead times may be incorrect.
Please see: http://www.hondata.com/forum/viewtopic. ... 43#p115543
Lomanrams21
Re: Fuel Maps
They were wrong thank you!
