k24z7block-k20z3head stage2 cams type s oil pump
aime88rob
Post by aime88rob »
hey i was wodering if someone have done something similar in a 8 gen i had to relocte the crank sensor ive tryed the k20 and the k24 sensor and it runs and sty t the same idle but ive got a po335 crank sensor code any chnce someone could guide me a lil bit ive tryed switching the pin too still run the same nd im running the crv long block with the z3 head map since i aint able to get a dyno pull untill the end of next week
Re: k24z7block-k20z3head stage2 cams type s oil pump
I don't believe that that block can be used as it will not have the correct sensors in the correct locations with the correct number of teeth.
aime88rob
Post by aime88rob »
aime88rob
Post by aime88rob »
aime88rob wrote: Mon Jun 28, 2021 9:58 am Image
What if I put a 9 gen computer and program my key for that computer would it work
I'm sorry, but this is not recommended or supported.
