Kpro limp mode and no communication
Dthquazi
Post by Dthquazi »
Kswapped miata. Engine and ecu setup has run well for several months. Hooked up a hondash setup using the USB c output.
Took the car to an endurance race this weekend. Heat was definitely an issue and overlooked some cooling for the ecu. Middle of the second day we got the issues. Key on and no information output to the gauges. Car was limited in revs (3k?) and had no power. Could not connect with Bluetooth. Key on key off did not fix the issues. Power cycling would fix the issue but not everytime.
Try to pull codes and don't find any stored.
Thinking the heat fried something but not completely. Where should I start?
Dthquazi
Re: Kpro limp mode and no communication
Post by Dthquazi »
Kpro serial 51823
Ecu pnd-a08
This K-Pro was sold as an install kit to Xenocron Tuning. It could be an installation issue. You should contact them to have it checked out.
Xenocron Tuning Solutions
379 Spook Rock Road (J502)
Suffern NY 10901 USA
845-504-5340
KPro installer
On site Reflash
chrisharris@xenocron.com
www.xenocron.com
