Can I use ECT-2 to display Oil Temp?
Crit
Post by Crit »
Thinking about putting a sensor in the oil pan and I was wondering if I could wire the sensor to the ect2 connection on the ecm and then display the sensors reading on the hondata mobile app.
Re: Can I use ECT-2 to display Oil Temp?
No, this will not work as it uses this temperature reading for other things.
Crit
Post by Crit »
I was under the impression that the ect2 is not utilized since it can be used for an AFR sensor
It can be, but that is quite a bit different.
