Red flashing light
jtr316
Red flashing light
Post by jtr316 »
What does it mean if the D2 led is flashing red? It only flashes red when I plug in my data log cable, everything works fine except for data logging, my AFR and Oil Press doesn’t move and just displays a value on the screen. I don’t know what changed but everything worked flawless a couple weeks ago..
Re: Red flashing light
Is J12 cut on the ECU?
jtr316
Post by jtr316 »
Yes, j12 is cut. I’m using a p06 converted to p28 if that matters. I was using the latest beta until yesterday I downloaded 2.7.7 but it’s still the same issue.
Post your calibration as well as a datalog showing the issue.
jtr316
Post by jtr316 »
my afr and oil pressure displays a constant value all the time, only my boost controller works. I've tried all the other inputs D12 D14 B6 with same results.
Why do you have an analog input for flex fuel, but have flex fuel disabled?
What is the serial number on the s300 board inside the ECU?
jtr316
Post by jtr316 »
It was hooked up before but never got it working right. serial is 50173
jtr316
Post by jtr316 »
i'm going over some steps with aem to see if it's the gauge cause none of the two buttons on it work anymore
jtr316
Post by jtr316 »
Got it working again. i swapped out the wide band sensor with a working spare and it's normal again, seems like the just the signal wire for wide band that I was using went bad or something
