Create Boost Tables Question
G. Wiffington
Post by G. Wiffington »
Good afternoon all,
For creat boost tables, if you set it how you want & then go to your map..if you select to only show N/A tables only (to make adjustments) does the creat boost tables forget/erase the setting changes you made in regards to retarding timing per PSI?
Re: Create Boost Tables Question
It does not change the tables, it just hides them from view.
G. Wiffington
Thank you for that confirmation!
