Cars spec -
k20a2 engine with pra ecu kpro v2
stock inlet manifold (code: prb I think)
4-2-1 manifold
skunk2 2.75" megapower exhaust
tegiwa induction kit (gruppe m)
stock ep3 injectors, stock tb
Does anyone have a file for this setup/similar setup?
or does anyone have a tune with the same setup but for a prc inlet manifold
2005 UK EP3 K20A2 PRA Intake and exhaust map required
- CalibratEd
- Contact:
Re: 2005 UK EP3 K20A2 PRA Intake and exhaust map required
I can assist you with a tune. Does the car have a working wideband?
-Ed
-Ed
Instagram: calibrated.tuning
it is just running the 2 stock o2 sensorsCalibratEd wrote: Fri Jul 09, 2021 7:23 pm I can assist you with a tune. Does the car have a working wideband?
-Ed
- CalibratEd
- Contact:
Ok, reach it to me if you install a wideband. I can not assist you if I can not get an AFR reading.r2isy wrote: Sat Jul 10, 2021 2:16 amit is just running the 2 stock o2 sensorsCalibratEd wrote: Fri Jul 09, 2021 7:23 pm I can assist you with a tune. Does the car have a working wideband?
-Ed
-Ed
r2isy wrote: Thu Jul 08, 2021 4:04 am Cars spec -
4-2-1 manifold
