New to Hondata
Minamoto
New to Hondata
Post by Minamoto »
Trying to make sure everything is ok for the 93 Base map Tune. Seems like something is holding my boost back a bit. Didn't know if anyone is able to help me. Any Help is appreciated.
Uploading my first datalog of driving to a spot and doing a 1-3 gear pull. Tried to keep it nice and short.
Re: New to Hondata
Boost is low. Intake temperatures are very high, which is probably the reason.
BTW don't drive into the rev limiter. It is not good for the engine.
Minamoto
Re: New to Hondata
Post by Minamoto »
It was like 90 degrees out. I'll have to go out at night to try log.
Minamoto
Re: New to Hondata
Post by Minamoto »
70 degrees outside definitely helped, saw 24 psi on the gauge. Posted 2 more logs, I don't usually go to the limiter, just did it for the one log.
Re: New to Hondata
I think the AFM could use some tweaking - a the higher flow it is under reading by about 4-5%, and it is best to get negative fuel trims.
Minamoto
Re: New to Hondata
Post by Minamoto »
What would cause that? I'm not confident to tune it myself outside of the base maps. Would moving down to a 91 base map help that? Been told our 93 is kinda iffy around here sometimes.
Edit* I don't believe the gas I got has ethanol in it but I did check the ethanol free gas. Also not sure if this would change it. Also appreciate you taking your time to help me out.
Re: New to Hondata
Selecting E10 fuel will give you a 4% fuel trim that would be about right.
Minamoto
Re: New to Hondata
Post by Minamoto »
I will try this asap when I'm off work, really appreciate the help. Ill try to get a log when it cools down again.
