Flex fuel sensor
Undefined4door
Flex fuel sensor
Post by Undefined4door »
Is it possible to wire a flex fuel sensor into a 2005 tsx running 07 ecu and flashpro?
Re: Flex fuel sensor
You need a Flex fuel sensor and controller to use it.
Undefined4door
Spunkster wrote: Fri Jul 09, 2021 1:52 pm You need a Flex fuel sensor and controller to use it.
ok just wanted to make sure it was compatible with the tsx ecu. I would just wire it to b22 or b12 correct? Or do i use the secondary fan switch?
You can use any of the inputs listed in the drop down in the Ethanol input section.
Akutl1
Post by Akutl1 »
Is the controller just a PWM converter to give the factory ecu Voltage instead? Will a basic voltage converter work?
More or less they are frequency to voltage converters with a buffered output (not duty to voltage or 'voltage converter'). It has to cope with the error frequency. If you go this route it depends on how good you are with electronics and how much time you want to spend getting it to work.
Akutl1
Post by Akutl1 »
Hondata wrote: Wed Jul 21, 2021 8:00 am More or less they are frequency to voltage converters with a buffered output (not duty to voltage or 'voltage converter'). It has to cope with the error frequency. If you go this route it depends on how good you are with electronics and how much time you want to spend getting it to work.
What's the best pin to use with A71 Ecu? 2006 TSX Manual.
You can use any of the listed inputs when you have the calibration open and look at the flex fuel options.
Undefined4door
Is there a controller you can recommend?
There are 2 listed in the help file we know work: https://www.hondata.com/help/flashpro/e ... htsub=flex
