S300 Unknow Device
Felicio90
S300 Unknow Device
Post by Felicio90 »
I have one problem when i connect my s300 the computer not recognize.
I have every time the message unknown device.
Somebody knows the problem?
Re: S300 Unknow Device
Felicio90
Post by Felicio90 »
Serial 50869
When did this problem start?
Felicio90
Post by Felicio90 »
Yesterday i try connect and start the problem.
I cant connect bluetooth a now USB
Felicio90
Post by Felicio90 »
i try another PC and do the same.
What has changed in the vehicle since the last time it was working?
Felicio90
Post by Felicio90 »
Nothing has changed on the car since the last time I used it.
First it started not connecting with bluetooth and now I can't even with usb
Who socketed the ECU?
Have you looked at the solder joints to make sure they look good?
Felicio90
Post by Felicio90 »
yes I checked everything everything is in good condition.
the car works fine without any problems.
I just can't connect to the PC
Have you tried a different laptop?
Felicio90
Post by Felicio90 »
Yes
Felicio90
Post by Felicio90 »
tomorrow I will try the board in another ecu
Felicio90
Post by Felicio90 »
So i try another ecu another pc and another car. I have the same issue. Can you help me?
Was the same s300 used on the other ECU?
