Looking for F22B SOHC VTEC stock basemap
aduncan1511
Post by aduncan1511 »
I need a stock basemap for a F22B SOHC VTEC 2.2L ENGINE. All I have installed is a cold air intake and 4-Dr Stainless Racing Manifold Header Exhaust. Any help or advice is appreciated! Also the base map on the ECU is for a H22A. Could I work off that or or should I start fresh?
CalibratEd
Re: Looking for F22B SOHC VTEC stock basemap
Post by CalibratEd »
aduncan1511 wrote: Sun Jul 18, 2021 12:19 pm I need a stock basemap for a F22B SOHC VTEC 2.2L ENGINE. All I have installed is a cold air intake and 4-Dr Stainless Racing Manifold Header Exhaust. Any help or advice is appreciated! Also the base map on the ECU is for a H22A. Could I work off that or or should I start fresh?
Any base map that you use will need modification. I would start with the H22 base map and then dial it in but adusting the injectors and dialing in the fuel. Hondata does not provide a base map for your engine. Any that you will find lingering on multiple forums is a modified P72 base map or modified H22 basemap.
I can help dial in the tune but you would need to have a wideband.
-Ed
Instagram: calibrated.tuning
ghostaccord2.3
Post by ghostaccord2.3 »
would you possibly be able to help me as well? tuning f23a1 stock with cat back just looking for a base to build off at the moment @ed
