P0299 disable
Civic 2016+ 1.5 Turbo
200HP EP
P0299 disable
Post by 200HP EP »
Car: Civic Si 2018
Mod: 27WON intake + flashpro
Everytime I turn off my Cruise Control Main to disable the revhang, sooner or later I get a P0299 code. I know I should disable this P0299 code via flashpro. But if this code is disable, do I risk to miss other problems that could hurt something else seriously?
Re: P0299 disable
It is an underboost error. It occurs when the boost tables have been raised higher than what the turbo can provide, especially when spooling. Disabling it in itself will not cause any problems, the only downside is that you might miss a boost leak if you somehow split a hose etc.
