37820-PRC-013 Wideband O2 issues
Hex
Post by Hex »
Hi
Need some guidance to get factory wideband working.
2005 Accord JDM CL7 K20A
ECU is 37820-PRC-013
Hondata info: Serial 10021, Firmware: 3.00, Software 4.4.60, ECU type: PRB - US RSX Type S
Currently there is no change in the Primary O2 current and the AF does not move.
* We have continuity traced all the O2 sensor wires / pins, they seem to be fine. Signal goes to A6, signal ground to A16 and there is heater voltage and
ground.
* We have fitted a new genuine sensor.
* Parameter menu, radio button set to "Built in wideband"
Anyone got any ideas?
Re: 37820-PRC-013 Wideband O2 issues
You need to try the ECU in a known working vehicle.
The K-Pro is not supported in an Accord.
Hex
Post by Hex »
Hi
Thanks for your reply. This is using an adapter loom (hence why we checked the pin continuity), and everything else works fine. As far as I can tell the O2 sensor is the correct one for the ECU. Any other ideas?
No, you need to try it in a known working vehicle.
Hex
Post by Hex »
ok thanks
Hex
Post by Hex »
Can't get a test vehicle. Can we send you this ECU? Must be some kind of plan b?
Where are you located?
