Speedometer not working
Dominique007
Post by Dominique007 »
I have an 06 RSX type S. K20 head, k24 block. Added KPro with PRB-A08 ecu and the jumper harness. The speedometer is not wotking on the original dash cluster. I heard that the ktuned vss cluster doesn't work for 05-06 RSX. What can I do to fix my speedometer?
Re: Speedometer not working
What do you mean by "ktuned vss cluster"
Dominique007
sorry, i meant vss converter, not vss cluster. I'm not by the car so I don't have the serial #, it's the red board though.
I need the serial number that is on the K-Pro board inside the ECU.
