Installed new fuel pump and now stumbling around 5k RPM
byk24mr2
Post by byk24mr2 »
Any insights from looking at the calibration and log? This is on a K24 MR2 Spyder.
I know the idle is low- I need to adjust the idle stop screw.
Calibration and log file attached.
test 1.kdl
Dyno Tune.kal
Re: Installed new fuel pump and now stumbling around 5k RPM
Does it do this if you put the original pump back in?
byk24mr2
Post by byk24mr2 »
I haven't swapped it back, but the reason I put the new pump and filter in was the original (MR2 Spyder OEM) starting running lean under load. It was actually around the same RPM as the stumble here, but I could see the AFR run lean. I had run a tank empty and then got on the track, so I assumed the original pump and filter were shot. The new pump is a DW265.
Check fuel pressure when this happens.
byk24mr2
Post by byk24mr2 »
Will do- thanks. I did check fuel pressure after the new pump/filter in the garage, but not while driving. It looked fine, but there was no real load.
I'll recruit a friend to watch the gauge later this week under load.
