Primary O2 Sensor not in jumper harness
skubasteeve
Post by skubasteeve »
Curious if I should have my PH02S connected to my ECU with the white wire or not, I currently have an X-Series UEGO connected to D14 and reading fine
S300 v1
B20B Turbo, RC750, PT5858
Re: Primary O2 Sensor not in jumper harness
Are you inputting a narrowband signal to D14?
skubasteeve
Nope, D14 is getting signal from the Wideband currently
You should not use D14 as it cannot see the full voltage range. Use D10 instead.
skubasteeve
I plan to get there, I am just curious if its necessary to have the actual PHO2S white wire connected to something.
Also, if I use D10 I have to possibly remove some resistors?
No you do not need it if you run closed loop from the wideband signal.
skubasteeve
I hooked up D10 to wideband and adjusted in hondata and I am only reading 18 afr... is this a symptom of needing to cut the resistors?
Is D10 still connected to its original location or is the wire cut?
skubasteeve
Wire was cut
Figured it out by cutting the resistors all good now
