Civic 1.5T CVT gearbox, how to make the turbine not work when stepping on the brake and accelerator at the same time
Civic 2016+ 1.5 Turbo
cyh60108
Post by cyh60108 »
Hello, I'd like to ask how to set the + 6psi CVT model I'm using now. When I step on the brake and accelerator at the same time, the turbine doesn't work. I'm afraid my car will break down when it's driven by others.
Re: Civic 1.5T CVT gearbox, how to make the turbine not work when stepping on the brake and accelerator at the same time
You should not hold the brake and press the accelerator at the same time as this will damage the transmission.
cyh60108
Post by cyh60108 »
Spunkster wrote: Tue Aug 24, 2021 12:10 pm You should not hold the brake and press the accelerator at the same time as this will damage the transmission.
I wouldn't do that myself, but sometimes others will drive my car. I'm not sure what they will do. I want to know if it is possible to set a limit to the engine speed and the turbine does not work when the brake and accelerator are pressed at the same time.
You can power brake when the vehicle is not moving. Sorry, no way to disable it.
cyh60108
Post by cyh60108 »
Hondata wrote: Wed Aug 25, 2021 7:33 am You can power brake when the vehicle is not moving. Sorry, no way to disable it.
Thank you for your reply
