Lambda Percentage Trace
Themyth
Post by Themyth »
I am having a issue with the lambda trace. I have set up my target lambda values correctly. When I view the lambda percentage correction trace, it does not plot a percentage in 500/750/1000 rpm rows or most of 12/21 KPA load columns.
Why is this happening??
I never had this issue with S300.
Re: Lambda Percentage Trace
Please post the datalog. It probably is your settings, but it would be unusual to get values on the 500 rpm row unless you idle was very low.
