Base Ignition Curves
kraquepype
Post by kraquepype »
My car was tuned a while ago, and I got to comparing its tune with some of the basemaps. I'm looking to improve my part-throttle tuning and behavior.
My low-speed ignition map looks vastly different at low RPMs, it is flat until around 1500RPM.
Would there be anything to gain by switching over to a curve similar to the basemaps, or could there be a reason mine was tuned this way? It's a stock B16B so it shouldn't be too much different. I've attached some screenshots.
Re: Base Ignition Curves
I would recommend discussing this with your tuner.
Dexorcist
Post by Dexorcist »
Changing that small flat section into a curve will not improve anything, because its basically at idle. Your map looks fine.
