Ignition timing says 50° at idle, then fluctuates
Qosmo
Post by Qosmo »
My idle ignition is reading at 50° in hondata. I have an obd2 dizzy with a harness to obd1. I double checked the wires are going to the correct places.
Re: Ignition timing says 50° at idle, then fluctuates
Has the distributor timing been properly setup using a timing light and the set timing function?
