Boost by Ethanol Table
Semin1907
Post by Semin1907 »
Hello Dears ,
I want to use boost by ethanol table but when i change the values it disables Flex Fuel Support on Mods Section and car goes with main boost airc table.
I want to use with ethanol 0 for lower the boost and over e20 i want to icrease airc.
For example i want to use 0 ethanol airc as 225 and for e20 i want to use 240 airc.
Re: Boost by Ethanol Table
Notes from the modification "Full flex fuel support for existing calibrations. Default air charge limit tables."
If you change the air charge tables then the modification is no longer shown as selected. This does not mean that flex fuel support is disabled.
Semin1907
Post by Semin1907 »
Hello
If default airc always limits the tables , how can i use flex fuel boost by ethanol limit. Car always tries to go with default airc table.In the case below i want my car goes with 225 airc but it uses 240 airc.
Flex Fuel Support Enabled ,
FlexFuel sensor reads ; e4
Default airc for 5000 rpm ; 240
Boost by Ethanol Limit 0 table ; 225
Post the calibration and a datalog.
Semin1907
Post by Semin1907 »
Hello
Here is the datalog and calibration.
It gets there. The ECU Air Charge control is not perfect and it your case it lags about 1000 rpm behind the table.
