brand new kpro error upload failed / clear security fail
OblivionPO
Post by OblivionPO »
version: 4
processor: NXP
datalogging mem test: passed
SN: 60017
main firware version: 19.00
Software version 4.4.9.0
secuirty disabled
says driver installed, online, ignition on at the bottom. ground is on the valve cover per tech data
mods:
DC5 chasis,06 k24a2 engine, rbc intake, sri
cal:
stock 04-05 tsx
Trying to flash the ecu, engine was running fine on the prb ecu before sending it off to get kpro'd
Re: brand new kpro error upload failed / clear security fail
Who did the KPro installation?
OblivionPO
Heeltoeauto but I believe they just sent it to you directly.
OblivionPO
Hondata wrote: Sun Nov 14, 2021 12:50 pm Who did the KPro installation?
Heeltoeauto
Tried again today after uninstalling and reinstalling kmanager. Just seems to be getting errors with anything I try.
Tried to update drivers, and it says "error updating drivers(error:)
I read through the help guide a bit. Should I try taking the cover off and looking at what the red/green LEDs are indicating?
This K-Pro was installed by VIP Performance and not by Hondata. You will need to contact them.
OblivionPO
Spunkster wrote: Mon Nov 15, 2021 11:49 am This K-Pro was installed by VIP Performance and not by Hondata. You will need to contact them.
Okay but is there any troubleshooting I can do on my end to try to get it to work?
You will have to determine where the problem is and correct it. Since it works on a known working vehicle, there is nothing wrong with the ECU or K-Pro.
OblivionPO
Where did I say it works on a known working vehicle? Just that the car still runs the same as it did before the kpro. It won't flash though.
Via email you said you tried it in a different vehicle and it worked as it should.
OblivionPO
Spunkster wrote: Tue Nov 16, 2021 10:04 am Via email you said you tried it in a different vehicle and it worked as it should.
You might have me mixed up with someone else. This is what I sent you guys.
I took the cover plate off and the green led never turned on the red led would flash with ignition on.
I am trying to find another vehicle to try it in but I live on a military base and I've never seen a rsx/ep3 here or in the small town outside of base. What other cars can I try the ECU in? There is a guy with a 9th gen si in my unit and I have a FK8 and 3rd gen TL
Please double check the serial number on the KPro because we did not sell 60017 to HeelToeAuto
OblivionPO
Hondata wrote: Wed Nov 17, 2021 8:30 am Please double check the serial number on the KPro because we did not sell 60017 to HeelToeAuto
60017 is correct. I guess heeltoeauto sent it to Vip Performance for the installation. Haven't been able to get ahold of them for troubleshooting yet.
Another thing to add. When I go to download from the ECU the file it returns is the one I'm trying to flash to it. Almost like it did take the flash but is giving the error upload failed incorrectly.
OblivionPO
Can I get an answer to any of my questions? What other cars can I test the ECU in. The green led never turns on at any time so it's a bad daughter board correct?
All KPros are tested before being sent out, so it is an installation fault. You need to contact whoever did the KPro installation.
OblivionPO
Sent it back and they fixed the install and it's working now.
So for future reference if you get clear security fail it's an installation issue.
Also to eliminate it being a wiring issue you can use a multimeter to shoot for correct ECU/sensor voltage. I followed this tech data, but if this happened to me again I would just skip that and send it back right away I was just hoping it was something I could fix on my end.
https://www.phearable.net/information/t ... grams.html
Hope that when I get a flashpro for my fk8 it goes smoother
