KManager Crashed Whilst Flashing ECU Now Car Wont Start And KManager Wont Connect
itstommmm
Post by itstommmm »
KManager Crashed Whilst Flashing ECU Now Car Wont Start And KManager Won't Connect, changed a couple of bits in my software calibration and got about halfway through uploading to car, the software crashed and closed, restarted the software and now my car isn't starting and my KManager won't see the ECU, when ignition is switched on the software says ignition off and error, any help appreciated please as my car is now stuck in a location it shouldn't be in.
Re: KManager Crashed Whilst Flashing ECU Now Car Wont Start And KManager Wont Connect
fastfu
Post by fastfu »
I was just about to post the exact same thing to the letter, Is this something that Hondata has done in the newest update ?
My car was running fine. I then went in to Kmanager and it said there was an update (because i hadn't used it since may) and installed it, made some changes to the calibration and got about halfway through uploading to car, the software crashed and closed, restarted the software and now my car isn't starting and my KManager won't see the ECU, when ignition is switched on the software says ignition off and error
There's no problem with the latest software. The questions you need to answer are in the post above yours.
