set ignition timing
stephancrxboosted1
set ignition timing
Post by stephancrxboosted1 »
hello, I have a built B16A1 and it is ready for the first start, only now I want to sync the ignition with my s300 p28 ecu.
I have a timing light but there is nothing else on it, so I can only time it on tdc with advance disabled. Now my question was, if I set the distributor exactly to zero and in s300 at the '"set timing" instead of 16 degrees also set it to 0? or does it not work like that..
Re: set ignition timing
Are you saying that the crank pully doe not have the correct timing marks on it?
stephancrxboosted1
well no I mean my timing light doesn't have a display or anything like that to set those 16 degrees that hondata asks for in "set timing" to sync the ignition timing. You can also set 0 degrees there instead of 16 degrees
TTR
Post by TTR »
If you don't have an advance timing light go to online, set timing, leave it at 16 and turn the distributor to the middle of the 3 marks on the crank pulley.
That should be 16 degrees assuming the marks on the pulley are correct.
stephancrxboosted1
Ok thanks i will do that.
